JHB545
May 18, 2023Aspirant
Wifi calling struggle with Orbi mesh. Need help please
Newby here. I have an Orbi RBR 850 mesh in my home with Spectrum supplied modem (Spectrum’s Technicolor ET2251) Wifi works fine. My Wifi calling with a variety of iphones is horrible. When and i...
May 18, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What iOS is loaded on the iPhones?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64 or try 500 or 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling SIP ALG under Advanced Tab/Setup/WAN Setup and test WiFi phone calls.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
- JHB545May 18, 2023Aspirant
Thanks for the detailed reply!!!
The modem is Spectrum’s Technicolor ET2251
I have two satellites deployed, each on a different floor from the base router. Close to 30feet apart, but maybe not quite. I figured being on different floors, makes 30ft requirement less important??
Modem is right next to router, with good cable in between. I have power cycled modem and router many times, and router has had firmware updates. (Not sure how to update modem???)
We have neighbors, but only two visible to me.
Have tried different bands.
- FURRYe38May 19, 2023Guru - Experienced User
Yes distances are important for any MESH system.
What channels are you currently using now on the RBR?I would try this, turn OFF the RBS. Then try a WiFi call with just being connected at the RBR.
Armor, Smart Parental Controls or Circle, Traffic Meter.Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64 or try 500 or 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling SIP ALG under Advanced Tab/Setup/WAN Setup on the RBR and test WiFi phone calls.
