JHB545
May 18, 2023Aspirant
Wifi calling struggle with Orbi mesh. Need help please
Newby here. I have an Orbi RBR 850 mesh in my home with Spectrum supplied modem (Spectrum’s Technicolor ET2251) Wifi works fine. My Wifi calling with a variety of iphones is horrible. When and i...
JHB545
Thanks for the detailed reply!!!
The modem is Spectrum’s Technicolor ET2251
I have two satellites deployed, each on a different floor from the base router. Close to 30feet apart, but maybe not quite. I figured being on different floors, makes 30ft requirement less important??
Modem is right next to router, with good cable in between. I have power cycled modem and router many times, and router has had firmware updates. (Not sure how to update modem???)
We have neighbors, but only two visible to me.
Have tried different bands.
May 19, 2023Guru - Experienced User
What iOS is loaded on the iPhones?
Yes distances are important for any MESH system.
What channels are you currently using now on the RBR?
I would try this, turn OFF the RBS. Then try a WiFi call with just being connected at the RBR.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64 or try 500 or 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try enabling SIP ALG under Advanced Tab/Setup/WAN Setup on the RBR and test WiFi phone calls.
