muusicman
Jul 09, 2023Aspirant
Wifi Congestion Netgear Orbi RBR850 Router/RBS 850 combination
Hi. I was wondering if anyone here knows how to fix this? I have Gig speed fiber from a local compay. I’m in a small town. My wired PC gets around 950 Mbps up and down. My wifi seems weird though. Als...
CrimpOn
Jul 09, 2023Guru - Experienced User
If the Roku is connected to that switch which is in turn connected to the RBR850 router (not a satellite), then WiFi plays no part in how it performs.
Initial loading (the time between selecting "Play" for a video and the video actually beginning to stream) may be a function of which video source is being used. As I recall, Roku is a platform which supports a large number of 'apps' (such as PrimeVideo, Netflix, BritBox, Disney, etc. etc.) Correct? Do all of these apps exhibit the same "loading" behavior? Do any of them suffer during actual playback?
- muusicmanJul 10, 2023AspirantAll of them
- FURRYe38Jul 10, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
muusicman wrote:
All of them- CrimpOnJul 10, 2023Guru - Experienced User
More detail may be helpful:
- Which specific Roku model?
- How many seconds elapse between selecting a video and playback starts?
- The Original Post said "sometimes" it load slow. What is the difference (in seconds) between normal and sometimes?
