cclark1974
Apr 21, 2021Aspirant
Wifi continues to drop connection with Google Chromebooks
Im having a real problem, the Wifi on the Google Chromebooks that are connected in my home wifi continually is dropping, I had a conversation with support we made a few changes it still has been an i...
cclark1974
If I disable AX mode Iose Wifi6 for compatible devices right? I CTS set to 2437 on both 5Ghz and 2 Ghz channels...
Apr 21, 2021Guru - Experienced User
Yes. Something to try on 2.4ghz only and see if the devices continue to drop connection...
Not the first time these device have had problems with Orbi AX.
