duomono
Aug 26, 2021Star
WIFI disconnecting 2-3 times a day with Orbi RBK852/850 (Satelite)
Hi all Just bought the Orbi 6 RBK852/850 2 weeks ago … the coverage and speed is good but the Wifi network discounting 2-3 times a day is a huge headache when your home is set up with ‘smart’ but ...
- Sep 17, 2021Hi … it has been 5 days and I’m happy to report that my wifi network has stayed up!
What I’ve done … installed the Beta for 850 as recommended, then I rebooted the system by first unplugging the modem, router and satellite for 5 minutes before turning them on. I gave a 2 minutes gap (as suggested) when turning on modem, followed by the router, then the satelite.
With the stability, our network is running a lot faster and the coverage is pretty amazing. Cheers for all the help!
Aug 26, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
duomono
Sep 03, 2021Star
Hi there, sorry for the delayed reply as I wanted to make sure how it has been disconnecting over the last 7 days. I can confirm that the WIFI disconnect at least once a day with the internet from our modem running perfectly fine.
V.3.2.18.1
Telstra Smart Modem Gen 2 (Technicolor DJA0231) Firmware 20.3.c.0329-MR19-RB
WIFI switched off
Approx 2000sq ft
About 30 ft
None, country/rural property.
I've set channel to 11/44
Armor.
Done
Done. (I've disabled 20/40 Coexistence)
Will keep everyone posted if this works.
