alternet
Sep 12, 2024Tutor
WiFi dropping every day. Only reboot helps
Hi all, I do have a problem with my RBR850. Since a few days it is constantly dropping WiFi: on the router everything is OK - no issues but no device can connect getting stuck at "getting IP addr...
CrimpOn
Sep 12, 2024Guru - Experienced User
alternet wrote:
I do have a problem with my RBR850. Since a few days it is constantly dropping WiFi: on the router everything is OK - no issues but no device can connect getting stuck at "getting IP address". Only reboot helps for a few hours.
RBR850 has 4 satellites.
All firmware is up to date (1x RBR850: V7.2.6.31_5.0.24, 2x RBS850: V7.2.6.31, 2x RBS350: V4.6.14.3)
Do you know when the firmware was updated on the router and the two 850 satellites?
There have been many posts on the forum from users who have the 350 satellites connected to a 750 router and "things went bad" when the 750 was updated to version 7 firmware. The consensus on the forum seems to be that the version 7 firmware is not compatible with the 350 router. When users returned the router firmware to the previous version (prior to v7), their systems worked again.
If this situation developed immediately after the 850's firmware was updated, my first thought is that the 850 has the same incompatibility.
- alternetSep 12, 2024Tutor
I always update the equipment as soon as new updates is published - I know now it is not too wise.
These were updated months back in the pas ....seems not to be related to the new version of firmware since my problems started days back in the past not months.
