alternet
Sep 12, 2024Tutor
WiFi dropping every day. Only reboot helps
Hi all, I do have a problem with my RBR850. Since a few days it is constantly dropping WiFi: on the router everything is OK - no issues but no device can connect getting stuck at "getting IP addr...
alternet
Sep 13, 2024Tutor
...it seems I got what was wrong. I deactivated IoT WiFi and it is stable for now. The only problem remains with RBSes ....the satellites do not want to connect.
- FURRYe38Sep 13, 2024Guru - Experienced User
The RBS850s are not connecting?
- alternetOct 08, 2024Tutor
nope.
Not connecting, ....sometimes connecting after a few hours, sometimes connecting after the satellites are rebooted, sometimes after the router is rebooted, ...
Today for instance got connected once the router started up…. But I do not have a clue why the router got restarted in the first place (the same was yesterday)! Real need to replace this Orbi by something more stable - any suggestions?
- FURRYe38Oct 08, 2024Guru - Experienced User
Need to turn OFF the RBS350s.
How are the RBS ethernet connected to the RBR? Directly behind the RBR? Or is there a LAN patch panel or LAN Switch in between them?
