propheci
Jul 30, 2022Aspirant
Wifi Drops - Hardwire fine.
Any luck on this? I think I'm in the same boat. Similar setup as OP: RBR850 with 2 satellites, both on ethernet backhaul.
I've had this setup for 2 years now. It's been fine until the past few ...
Jul 30, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- propheciJul 30, 2022Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
V4.6.8.2 on router and the 2 satellites.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Motorola MB7621. I'm with Xfinity.
3000
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Around 25-30 feet for both. They're both on ethernet backhaul though.
Auto and 48 on 5Ghz
Any Wifi Neighbors near by? If so, how many?No. I'm in a single family house. I can see some of my neighbors' networks but signal is much weaker than mine.
I was just poking around the logs on the Motorola modem. I see these messages that look suspicious.
Sat Jul 30 09:13:11 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0; Sat Jul 30 09:13:11 2022 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0; Sat Jul 30 09:13:11 2022 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0; Also, I take back what I said about hard wired devices being fine. I do recall now that sometimes they have problems, too.
- FURRYe38Jul 30, 2022Guru - Experienced User
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly or ethernet connected.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
