GoFisch
May 19, 2024Aspirant
WiFi Extension
Good morning, we currently have an Orbi RBS840 mesh system in our home. We have Starlink for our internet provider, our home is around 4k square feet and the coverage is good throughout the house. My...
GoFisch
Thank you for the response and you are correct, running a cable out there would be a challenge due to having to dig under sidewalks and foundation. Is there a different more powerful mesh system that would work? I will also look at the wireless bridge option.
CrimpOn
May 19, 2024Guru - Experienced User
All consumer WiFi systems have the same Fcc power limits. Their omni directional antennas are the issue. Bridge systems use narrow beam, high gain antennas to focus the energy in a narrow beam.
