RonGer
Jul 23, 2020Aspirant
WiFi Home Upgrade - Need Advice on Routers vs Mesh - Want WiFi6
I have a 6,000 sq ft home, with three floors of 2,000 sq ft. I previously installed about eight WiFi access points that were all routers as well. Of these 8 about 5-6 are also used for wired conn...
RonGer
thanks
Jul 23, 2020Guru - Experienced User
:smileywink:
- RonGerJul 23, 2020Aspirant
Is this the equipment list that I should buy?
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111- plemansJul 23, 2020Guru - Experienced User
RonGer wrote:Is this the equipment list that I should buy?
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111No, that's the the equipment/setup that FURRYe38 has. it can be a bit intimidating :) Especially since thats just the netgear equipment.
- FURRYe38Jul 23, 2020Guru - Experienced User
i won't brag about all the other non NG equipment I may have. :smileywink:
