CrazyEddie
Feb 15, 2022Apprentice
WiFi internet drops when I plug ethernet into RBS850
I have an Orbi system with one RBR850 and two RBS850s. I plugged an ethernet cable into the back of one of the satellites in order to access the internet with a laptop with a bad WiFi driver (long st...
Feb 15, 2022Guru - Experienced User
What CAT# cable are you using? CAT6 is recommended.
Is the RBS connected to the back of the RBR directly or is there a LAN switch or patch panel in between the RBR and RBS?
CrazyEddie
Thank you for such a quick reply. It is a CAT6 cable.
I looked at the link below for backhaul and I'm not sure that applies to my setup. My RBR is not connected to the RBS by any physical connection - just wirelessly. The RBR is connected to my Netgear modem by ethernet. The RBS in question is on a different floor from the RBR. My only reason to connect to the RBS with an ethernet cable is because this particular laptop no longer has WiFi capability and I was hoping to be able to connect to the RBS for an ethernet connection to the internet.
- plemansFeb 15, 2022Guru - Experienced User
Have you tested other devices other than just the 1 laptop?
- CrazyEddieFeb 15, 2022Apprentice
Tested in what way? I've only plugged in this laptop via an ethernet cable, as it is the only laptop or device that has this WiFi problem. I have tested other devices when the laptop is plugged in - phones, TV and other laptops are all unable to access the internet after the laptop is plugged in. Those other devices are able to access the internet after the laptop is unplugged and the satellite is powered off and on.
- FURRYe38Feb 15, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Have you tried connecting the laptop to the other RBS and same thing happen there?
And what CAT# cables are you using to connect the RBS? Check your LAN cables as well. These can cause problems. You may have a ARP storm happening that would cause the network to go down.
FURRYe38 wrote:And what CAT# cables are you using to connect the RBS? The laptop is connected via Cat6. There is no other wired connetion to the RBS. Check your LAN cables as well. I am not using a LAN cable. These can cause problems. You may have a ARP storm happening that would cause the network to go down.
CrazyEddie wrote:Thank you for such a quick reply. It is a CAT6 cable.
