CrazyEddie
Feb 15, 2022Apprentice
WiFi internet drops when I plug ethernet into RBS850
I have an Orbi system with one RBR850 and two RBS850s. I plugged an ethernet cable into the back of one of the satellites in order to access the internet with a laptop with a bad WiFi driver (long st...
CrimpOn
Feb 15, 2022Guru - Experienced User
CrazyEddie wrote:
The laptop was able to then access the internet, but connecting to the RBS seems to cause the WiFi for the house to work but without any internet access. Everything returns to normal (except the RBS in question remains "out of sync" - even after powering it down and also pushing the Sync button).
Could you provide a little more detail about the sequence of events:
- The laptop is plugged in and has internet access.
Does it continue to have internet access as long as it is plugged in? - When the laptop is plugged in, what happens to other devices which are connected to any of the Orbi units with ethernet?
- Every device connected with WiFi immediately loses internet?
- What is going on with the satellite that the laptop is connected to?
It must be still working because the laptop has internet, or
The satellite immediately shows "out of sync" even though the laptop continues to work? - When does everything return to normal?
When the laptop is disconnected?
Just by itself, except when everything else starts working again, the satellite goes "out of sync"?
CrazyEddie
CrimpOn wrote:
CrazyEddie wrote:The laptop was able to then access the internet, but connecting to the RBS seems to cause the WiFi for the house to work but without any internet access. Everything returns to normal (except the RBS in question remains "out of sync" - even after powering it down and also pushing the Sync button).
- The laptop is plugged in and has internet access. Correct
Does it continue to have internet access as long as it is plugged in? Correct- When the laptop is plugged in, what happens to other devices which are connected to any of the Orbi units with ethernet? There are no other devices connected to any Orbi units via ethernet.
- Every device connected with WiFi immediately loses internet? As far as I can tell. I have a lot of devices, but the phone in my hand and TV in the same room went out.
- What is going on with the satellite that the laptop is connected to? It seems to be unaffected
The satellite immediately shows "out of sync" even though the laptop continues to work? I have not watched the Orbi online interface as I'm plugging in - I haven't repeated it since I figured out the correlation, as I can't keep knocking out WiFi internet due to other obligations- When does everything return to normal?
When the laptop is disconnected? yes, after the laptop is disconnected and the satellite is powered down and back on - except it still shows as "Out of Sync" under Backhaul Status. The satellite does not show any blinking or other lights.
- CrimpOnFeb 15, 2022Guru - Experienced User
- It must be still working because the laptop has internet, or
Thanks for the information. Sort of a "Catch 22" because investigating the problem can interrupt internet access. Further diagnosis may have to wait until everyone else is asleep.
Just a silly question: On the laptop, has the WiFi adapter been disabled in network settings?
