POC60
Sep 20, 2024Aspirant
Wifi mesh RBS 350 satellite range suddenly reduced
Hello, I have a wifi Mesh router RBR350/RBS350 installed with a single satellite. The system has been running fine for at least 2 years. Suddenly the reception sone some devices in the 2.4 GHert...
Sep 20, 2024Guru - Experienced User
What devices are you speed testing with?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
POC60 wrote:
Hello,
I have a wifi Mesh router RBR350/RBS350 installed with a single satellite. The system has been running fine for at least 2 years. Suddenly the reception sone some devices in the 2.4 GHertz (e.g. Internet radio) has become too weak, so that the device is unable to connect. This is the conclusion I reached after doing a few tests. I did not change anything on either the router or the satellite configuration. I tried with a spare satellite to check if it was the coming from the satellite hardware. Same reception problems
What is happening and what can I do?
I remember from a netgear router 25 years ago that changing the Wifi chanel could resolve some problems.
ON the satellite setup page, the wifi channel is set to automatic. Should I try another value?Thank you in advance for your help!
POC60
Sep 28, 2024Aspirant
First of all, Thanks for your replies. I have taken some time to investigate the problem and I can't say I found an explanation.
First of all, hera are a few more additional facts:
- Router software version V4.4.1.29_3.10.80
- Satellite software version V4.4.1.29
- The satellite is wired to the router via Ethernet
- The reception problem is with an internet radio (2.4 GHertz band)
in the mean time, I also installed a Wi-fi ananlyser on my Mac (NETSPOT), which gives me more precise info on wifi signal strength. One of the observations is that signal strength at the Internet radio that could not connect is borderline. I moved the satellite closer to the radio. It seemed to resolve my problem. But guess what? The problem was back. And then, suddenly the signal becomes too weak .Moreover, it seems quite erratic. Netspot reads signal strenght fluctuating between -68dB and -91dB at different times in exactly an identical position.
I also tried to swap satellite (I have an extra unused one). But this does not change anything. I also switched off the Guest Wifi network to prevent potential interference: no effect
Finally, I tried with a different brand old 2.4 GHz ADSL router hardwired into the ORBI router and located next to my ORBI satellite. At times, ORBI signal strength can be 5 dB weaker than the old router.
I have the obvious solution of placing my additional satellite in the same room as the internet radio. It works (signal strenght -50dB).
What puzzles me is that I had no problem with the same radio and the same satellite for some 2 years. And then, all the sudden, signal strength seams to be weaker. Or maybe, is it possible that my Internet radio has become less "receptive"?
Pierre
Anyway, thanks for your help.
- FURRYe38Sep 30, 2024Guru - Experienced User
What is this internet radio? Is there a brand and model#?
Does this internet radio give off or broadcast a 2.4Ghz signal? If so and if it's in the same room or near the RBS, then this will cause some interferences and problems. Would be best to keep this device far away from the RBS.
- POC60Oct 01, 2024Aspirant
Hi,
The internet radio is read as Frontier Silicon by ORBI. Is is just a receiver, for listening to Radio programs over internet. So I doubt there are any interference. For a while, I suspected that the problem coud have orginated from a degraded Wifi receiver. But when I as able to measure the wifi signal power via NetSpot, I realised that the signal itself is too weak.What is strange is that I had no wifi signal strength issue for at least 2 years.
Is it possible that newer versions of the Satellite software would curb the power and the range?Thanks,
Pierre- FURRYe38Oct 01, 2024Guru - Experienced User
MIght try a factory reset and setup from scratch and see if this improves anything.
