KernJim's avatar
KernJim
Wifi Mesh System RBR850
I am a novice at this and have a basic question re: 2.4gHz usage of my RBK852 Orbi wifi mesh system.   (It was purchased 3 years ago and works fantastic).   I am considering purchasing a water detection system for my home that only works on 2.4gHz.   Is my system compatible with this product?  Can I purchase this product knowing it will integrate into my wifi system seamlessly?
I don't know how to check to see if my system is operating on 2.4gHz or 5gHz.
Thank you!  KernJim
1 Reply
  • plemans's avatar
    The RBK850 kit has 2.4ghz and 5ghz. It should work fine. sometimes you have to do a few workarounds for knockoff/generic stuff but its rare and doesn't happen nearly as much as it used to.
    so should be fine
