z8
Feb 06, 2022Guide
Wifi on iPhone 12 not as fast as expected
I have an RBR850 with one wired satellite and one wireless satellite, all running V4.6.7.5_2.1.7 Via ethernet I get my expected 920Mbps download, however running a speedtest with my phone from th...
Feb 06, 2022Guru - Experienced User
Is the phone connected to the RBR or RBS and at what distance is the phone from the RBR or RBS.
iPhones being only a 2x2 mimo antenna support, won't see anything near 900Mpbs. Even on AX mode. Mine maxes out at 700ish range when at close range with the RBR. Far range, anywhere from 200-300Mpbs depending.
