Redlightning88
Jan 27, 2020Tutor
Wifi shows on but nothing connects: Wifi Password is Incorrect
I have an AX setup that replaced an Orbi Pro setup. On the immediately prior AX setup, at least once a day the wifi would just disappear for everything (multiple devices showed no wifi). If I tried ...
Jan 27, 2020Guru - Experienced User
Sounds like the system could be faulty. If you have done resets and configured different things and it won't work well, I would make contact with NG support and ask for additional help and information and also ask about an RMA.
Redlightning88
Jan 27, 2020Tutor
It has already been RMA'd. This is the new unit that is having a variant of the prior unit's fault.
- FURRYe38Jan 27, 2020Guru - Experienced User
So with the RBS turned OFF, your devices are still experiencing this problem?
What happens if you disable AX mode on the RBR.
- Redlightning88Jan 27, 2020Tutor
Correct. Tried the satellite with wired backhaul, wireless backhaul and off entirely.
Hmm, sounds like something is not configured right or something in your environment is a possible cause. Very odd.
And you did disable AX mode on the RBR?
