Redlightning88
Jan 27, 2020Tutor
Wifi shows on but nothing connects: Wifi Password is Incorrect
I have an AX setup that replaced an Orbi Pro setup. On the immediately prior AX setup, at least once a day the wifi would just disappear for everything (multiple devices showed no wifi). If I tried ...
Jan 27, 2020Guru - Experienced User
Hmm, sounds like something is not configured right or something in your environment is a possible cause. Very odd.
And you did disable AX mode on the RBR?
Redlightning88
Jan 27, 2020Tutor
It is odd. There are very few configuration options in the AX compared to the Pro, and what there are are the same as they were configured in the Pro. And nothing changed in the clients that would cause this (there was literally a 10 minute break between connecting to the Pro and connecting with the AX, and it affects all devices not just some. The newest firmware did seem to affect the amount of time the AX would remain stable (in a positive manner), but everything eventually still goes to hell within a day. With the unit I RMA'd, I actually had to leave it for several weeks while travelling and put the router on a timer that would reboot it every day. That helped 90% of the time (sometimes everything would crap out before the reboot). Can do the same here but don't want a kludge "fix" to what is obviously just an issue with the router.
