Redlightning88
Jan 27, 2020Tutor
Wifi shows on but nothing connects: Wifi Password is Incorrect
I have an AX setup that replaced an Orbi Pro setup. On the immediately prior AX setup, at least once a day the wifi would just disappear for everything (multiple devices showed no wifi). If I tried ...
Jan 28, 2020Guru - Experienced User
What model # is this switch? This a managed switch or have any Green Ethernet features by chance?
Redlightning88 wrote:Wired backhaul straight to the RBS. Connection to TPLink 16 port gigabit switch for all other wired devices. Have 65 clients mixed between 2.4 and 5ghz and wired. Directv, AppleTVs, Sonos, projectors, Nest Protects, cameras, hubs and doorbell, computers, printers, iPhone and iPads and printers and pool equipment and garage doors etc. Same mess as was connected without issues to the Pros.
Redlightning88
Jan 29, 2020Tutor
It is one of their Easy Smart switches. And the regular Orbi and the Pro had no issues with it. And the satellite is straight wired to the Orbi base unit and not through the switch. I rebooted everything again yesterday am BTW and tried again using just wireless backhaul and a day later I'm still running. So maybe the hints I've seen on the forums that wired backhaul has issues may be relevant.
- FURRYe38Jan 29, 2020Guru - Experienced User
My RBSs are currently wire connected. And running thru switches, non managed and non green ethernet.
I have submitted a bug on the RBS connected to switches. I've seen odd behaviors with RBS wire connected.
Just last weekend the RBR in AP mode became unplug by accident over night. I plugged it back in thinking the system would all come back to ready, Ah no. Both RBS were online however the RBRs UI showed them as disconnected. I could not get them to show as connected until I removed 1 switch from the mix and and then wirelessly resync 1 RBS then wire connect it. Been good since then. Crazy experience.
:smileyfrustrated:
I also submitted a bug for xbox and Strict NAT. Thought this would be a separate issue.
