crunchy59
Jul 05, 2022Aspirant
Wifi slow speed on AX6000
Hello , I have put 3 AX6000 on my network. My service provider 1Gb, Speed test on LAN : 125Mb. on WIFI 19MB! However, the satellites are connected to 1Gbs switches which are also connected to 1G...
Jul 06, 2022Guru - Experienced User
Is this a Orbi system? If so, which model? AX6000 is not a model #
What CAT# LAN cable are you using?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Having too much wifi can also cause problems. For that size home you only need the RBR.
However, the satellites are connected to 1Gbs switches which are also connected to 1Gbs LAN.
On each switch where the satellites are connected, in LAN I have 120Mb in Wifi less than 20Mb.
I have try to reset factory, same pb: slow wifi connection, In 2.4 an 5GHz. My house is not big (under 100m²) And only 3 houses around me.
How can I do to increase the speed of the wifi?
Thanks.
C.
