Nettmann
Sep 27, 2020Aspirant
Wifi speed is too slow RBR 850 plus 2 x RBS 850
Hello, i am not super technical so forgive me if i don't give all the correct info. I bought the new Orbi Mesh System AX 6000 (RBK853) including 1 Router RBR 850 and 2 Sattelites RBS 850. I ...
Sep 27, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Is your wifi device AX supporting or only AC? Most AC wifi devices max out at around 400-500Mpbs on 5Ghz AC.
Install WiFiSweetSpots app on your device to check the connection rate between the device and RBR or RBS. You may have to temporarily disable the wifi radio on the device if you move near the RBS then back on to ensure it connects to the RBS instead of the RBR.
