Wizzard370
Nov 18, 2022Tutor
WiFi speed puzzle
I have Orbi 353 Mesh system. I was with Virgin Media 350 speed. Wired, I got the max 350+ speed. The WiFi was giving about 200ish nearly all the time. I have now swapped over to FTTP service ...
- Nov 19, 2022
Interesting... Rebooted the iPad and android phone and the speeds are as before - i.e. as they were with Virgin Media.
Nov 18, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
