Wizzard370
Nov 18, 2022Tutor
WiFi speed puzzle
I have Orbi 353 Mesh system. I was with Virgin Media 350 speed. Wired, I got the max 350+ speed. The WiFi was giving about 200ish nearly all the time. I have now swapped over to FTTP service ...
- Nov 19, 2022
Interesting... Rebooted the iPad and android phone and the speeds are as before - i.e. as they were with Virgin Media.
Wizzard370
Nov 18, 2022Tutor
The setup has not changed at all. I have moved from Cable to FTTP optical service. The Ethernet cable to my desktop PC gives full speed.
Issue is the WiFi
CrimpOn
Nov 18, 2022Guru - Experienced User
What device was used to make these Speed Tests?
Does Attached (or Connected) Devices indicate that this device is still connected to the router?
- Wizzard370Nov 18, 2022Tutor
Tested using Android Pixel 6 and Apple iPad. Both connected to WiFi and working.
- Wizzard370Nov 19, 2022Tutor
