Justadude123
Dec 25, 2022Aspirant
Wifi speeds faster than ethernet speeds also slow wifi speed
My router is in ap mode with my verizon fios router. Also thanks for any help i receive
Dec 25, 2022Guru - Experienced User
Not much to go on.
Can you give more details?
What NG product are you referring too?
- Justadude123Dec 25, 2022AspirantRbr753
- FURRYe38Dec 25, 2022Guru - Experienced User
What devices do you have connected?
How are you speed testing?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
