Joetile06
May 05, 2024Aspirant
Wifi ssid rbr750
Good evening all, I've had my orbi pretty much problem free for a few years now. Except the initial start up and programming all the 2.4 accessories to it is been great. Until 3 days ago, we had a pow...
May 05, 2024Guru - Experienced User
What FW is loaded on the RBR and RBS?
Try doing a factory reset and setup from scratch using this method:
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
CrimpOn
After being reset to the default WiFi credentials printed on the label:
- The device running the Orbi 'app' connects to the WiFi using those credentials and the app opens correctly?
- How is the device accessing the web interface connected? (WiFi or 'wired')
- After the WiFi credentials are changed and the router restarts WiFi, does the new WiFi SSID appear to devices as an available WiFi network?
- What is the error that devices display when the connection is refused?
- Joetile06May 05, 2024AspirantThe device running the Orbi 'app' connects to the WiFi using those credentials and the app opens correctly?
Yes it all works fine.
Wifi
Yes it does, and during one of my resets some of my wyze cams actually worked, though that was all that worked. My phone hasn't connected after any of the name changes.
Network connection failed is the most common one.
Hope that helps.
