x5m33k5x
May 04, 2022Aspirant
Wifi/Hardwired speeds drop to unusable speeds frequently RBK752-100CNS
Hi there, I am uncertain where to go with this issue I have been having issues with my Netgear orbi. Seems this is my only option since my support period has conveniently expired at the beginning of ...
x5m33k5x
May 05, 2022Aspirant
Thank you for your reply,
I covered 90% of your questions in my initial post. I am running cat6 throughout my entire house including between my Shaw bluecurve gateway and my orbi. Interference should not be a issue on my wired connections. This is also ruled out by the fact that everything works correctly when I use any of my other routers. My wired speeds are >600mb/s before the router slows down. When the router slows down the speeds are <2mb/s.
If you continue to read in my initial post, this issue also happens on wired devices. This is not strictly a wifi issue although it is present on wifi as well. I have reset my gateway multiple times before and after firmware updated while trying to troubleshoot this issue on my own. And I have also brought everything back up in sequence as you have recommended. No change.
Currently I am running the bluecurve gateway as a router and everything works as expected with great transfer rates that are consistent. I have also put the gateway in bridge mode with all security features turned off and used my old R8000 as the router and this works consistently as well.
To clarify, the NG R8000 router is not part of the network that I have set up any more. These orbis were to replace that old router. I was strictly using it for testing to rule out all other components of my current network. This condition only exists when the orbi is used as the interface.
Please let me know if you have any further ideas
Thank you
May 05, 2022Guru - Experienced User
Is one of these your ISP modem?
What wireless and wired devices do you have connected?
What is the distance between the router and 📡 satellite(s)?
How are the RBS connected to the RBR? Wired or wireless?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I would turn OFF the RBS and run just the RBR and speed test with.
Also a factory reset and setup from scratch maybe needed on the RBR.
