IanBlackburn
Jan 13, 2021Follower
Will a 2nd RBS850 help provide a decent signal in my Garage from Router in my house?
Hi I have an RBR850 with one RBS850 satellite which provides decent coverage throughout the house. We have an external garage about 1m from the house which needs Wifi access for various kit. ...
Jan 13, 2021Guru - Experienced User
the satellites need a decent signal to function off of. If there's not much for signal in the garage, thats what the satellite will pick up to use. and it'll be just as bad.
Maybe moving the router/satellite around in the home to cover more of the garage might help.
You could try running a wire, using a moca adapter, or trying powerline if the garage is on the same circuit.
