cojumdip
Jul 16, 2020Aspirant
Will a RBS750 satellite connect to RBR50v2 router?
Will a RBS750 satellite connect to RBR50v2 router? I've attempted to do so using the Orbi iOS app (remote management) and after following the instructions, pressing "sync" on the newer RBS750 and wai...
Jul 16, 2020Guru - Experienced User
Orbi AX and Orbi AC are not currently compatible.
Be sure to check out the Orbi AX forum for additional information and post there.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
- cojumdipJul 17, 2020Aspirant
Well that's fun that they still call it "Orbi" and don't tell you it's not compatible on the box. Will the "Wall Plugs" (RBK33) models work with my Orbi Router RBR50v2?
- FURRYe38Jul 17, 2020Guru - Experienced User
Yes.
Because is called Orbi doesn't mean the different models are compatible with each other.
