MozartEinstein
Aug 22, 2022Follower
Will an Orbi AX4200 work to strength signal of MR5100 Hotspot?
We have a 2000 sq ft shop and because AT&T Broadband wireless is the only service available to us (without major construction to the building) we were set up with a Nighthawk Mobile Hotspot (MR5100) ...
Aug 22, 2022Guru - Experienced User
Looks like the MR5100 has an ethernet port to connect devices to. You could attach an orbi setup to it and use the orbi in access point mode and just let the MR5100 handle routing.
- CrimpOnAug 22, 2022Guru - Experienced User
The product data sheet mentions,
"With the option to
connect the 5G Mobile Router to
your existing home router, you
can bring 5G speeds into your
home network and all your WiFi
devices."
