EclipseGSX23's avatar
EclipseGSX23
Will it work together?
I have a  Orbi Tri-band Mesh WiFi 6 System, 6Gbps Router + 2 Satellites   will the satellite of this  AX4200 WiFi Satellite (RBS750)   work with what I have?  All needs to be wireless.  Thanks ...
  • plemans's avatar
    Nov 07, 2021
    the 7 series satellites are compatible with the 8 series routers.
    so you can use that satellite with your router.
