EclipseGSX23
Nov 06, 2021Aspirant
Will it work together?
I have a Orbi Tri-band Mesh WiFi 6 System, 6Gbps Router + 2 Satellites will the satellite of this AX4200 WiFi Satellite (RBS750) work with what I have? All needs to be wireless. Thanks ...
- Nov 07, 2021
the 7 series satellites are compatible with the 8 series routers.
so you can use that satellite with your router.
EclipseGSX23
Nov 10, 2021Aspirant
Thanks!!! 2nd question. About far far in feet on average can the satellite be apart for the signal to go between the unit? Mine are about 20-25. I really could use 30-40 between
Thanks Mike
Nov 10, 2021Guru - Experienced User
20-25 is too close, 30 feet is recommended start distance or more maybe up to 50-60 feet depending.
- EclipseGSX23Nov 10, 2021Aspirant
Ty Furry!! Wish I had ya on FB. Could chat with ya there!!
Thanks! Helps us out alot!
Michael
