dorightdaddy
Sep 30, 2020Aspirant
Will Orbi Voice RBS40V connect to the RBR850 mesh system?
Just installed the new Orbi RBR852 wifi 6 mesh. I see that NG has an Alexa device Orbi Voice RBS40V-200 that will connect to any router. But I also see that the Voice may not connect to my RBR850 rou...
- Sep 30, 2020
the RBS40v is not wirelessly compatible with Orbi AX. You can ethernet connect the RBS40v to the Orbi AX system and it would work that way:
Be sure to visit the Orbi with Voice forum for the RBS40v information and help.https://community.netgear.com/t5/Orbi-Voice-WiFi-Meets-HiFI/bd-p/en-home-orbi-voice
This forum should have all information regarding the RBS40v.
Sep 30, 2020Guru - Experienced User
- dorightdaddyOct 01, 2020Aspirant
Thanks Furry for your fast, succinct reply. Unfortunately a wired solution will not work for my needs to expand the Orbi WiFi range in a large home and have Alexa in an all-in-one device. Hopefully NG will remedy this by coming up with a viable wireless device in the future.
- FURRYe38Oct 01, 2020Guru - Experienced User
Good Luck.
