dean92868
Apr 25, 2023Follower
Will SXR50 satellite from Orbi Pro WiFi 6 AX5400 work with ORBI 6 AX6000 router RBK852
Hi, I'm currently using Orbi Pro WiFi 6 AX5400 with SXR50 satellite. A friend is going to sell me his ORBI 6 AX6000 router but I dont know if my AX5400 satellite will work with AX6000 router. Are al...
CrimpOn
Apr 25, 2023Guru - Experienced User
Orbi and Orbi Pro are different product lines, using different firmware. They are not compatible.
I see only one Orbi Pro router that is compatible with more than one Orbi Pro satellite:
https://kb.netgear.com/000065558/Which-Orbi-Pro-routers-and-satellites-are-compatible
There is a similar table for compatibility between (ordinary) Orbi routers and satellites:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
