prufrock10
Aug 20, 2024Aspirant
Windows dropped connection new Orbi 750 AX4200
Weird situation. Just set up a new Orbi 750. Set up went well, I'm generally satisfied. We are a primarily an Apple household but my partner has a Dell windows laptop which keep dropping WiFi; an...
- Aug 20, 2024
Thanks all for the quick responses.
So, the strangest thing, I ended up simply choosing "Forget" on the network listing for our SSID; after that I reconnected and so far it's been holding just fine.
Will have to wait and see obviously but promising. Thanks again for the suggestions, leaving this up in case it helps someone else.
prufrock10
- FURRYe38Aug 20, 2024Guru - Experienced User
Glad it was a simple fix. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
