kwmeans
Jul 14, 2021Aspirant
Wink Hub (Original)
I just installed the orbi WiFi6 RBK752 (router + 1 satellite). Everything is working except my Wink hub. This is the original, not the Hub 2, and is several years old. It only uses 2.4Ghz but work...
Jul 14, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Please contact the Mfr for help and support information regarding there product.
Thank you.
kwmeans
Jul 15, 2021Aspirant
Thanks. The post is showing up in the Orbi (AX) community so I think if someone has an answer they'll see it.
I am trying to get the manufacturer to help but (a) they aren't the best at responding, and (b) this is an older model hub and I think their answer is basically "buy a new one. it should work." We'll see.
- FURRYe38Jul 15, 2021Guru - Experienced User
Try disabling AX mode on the RBR and set CTS values to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings
