EdinMyakka
Dec 18, 2020Aspirant
Wire vs. Orbi
I am looking to improve speeds in my home and I started by investigating getting the house wired for Ethernet. The guy who came in sugggested that I investigate the Orbi system. Frankly, plugg...
EdinMyakka
So for a 4000 sqft home on one level, this would work well?
Inside walls are plasterboard, byw.
- FURRYe38Dec 18, 2020Guru - Experienced User
Yes. Though you might try with just 1 RBS deployed first.
- MstrbigDec 18, 2020Master
EdinMyakka wrote:So for a 4000 sqft home on one level, this would work well?
I have the exact same system and it covers my 2 story home completely. I am sure it will cover your home well, providing you space out the router and satellites. On a 1 story 4000 sq ft home, depending on how long and deep the home is, you could place 1 unit on each end and one in the middle of your home for great WIFI coverage.
