araghava
Jul 10, 2020Star
Wired Back haul and 3rd band
Quick question: If I use a wired backhaul for my satellites, will the dedicated 3rd backhaul band then be used for regular data flow.
Jul 10, 2020Guru - Experienced User
The wireless backhaul is there for when the wired backhaul gets disconnected or goes down. Nothng that can be user configured. Sorry.
- araghavaJul 10, 2020Star
Thanks for the response. I'm not looking for user configuration. However I would have hoped that the wireless backhaul could have been used automatically for regular bandwidth when the wired backhaul is working.
- FURRYe38Jul 10, 2020Guru - Experienced User
It's sits idle until it's needed. Same with 1st gen Orbi AC systems.
