araghava
Jul 10, 2020Star
Wired Back haul and 3rd band
Quick question: If I use a wired backhaul for my satellites, will the dedicated 3rd backhaul band then be used for regular data flow.
araghava
Jul 10, 2020Star
Thanks for the response. I'm not looking for user configuration. However I would have hoped that the wireless backhaul could have been used automatically for regular bandwidth when the wired backhaul is working.
Jul 10, 2020Guru - Experienced User
It's sits idle until it's needed. Same with 1st gen Orbi AC systems.
