rafaleo
Oct 24, 2023Aspirant
Wired Backhaul Dasiy Chain - Orbi 850
Hello, I am trying to cover an area around 10K sqft - which I am using 1 router and 4 satellites. Backhaul connection is good and the coverage is nice. However I have 2 problems: 1- All th...
- Oct 24, 2023Hello,
I connected my laptop on the jack and it works wired connecting to internet (wireless turned off)
Firmware is 7.2.6.21
Oct 24, 2023Guru - Experienced User
Bring the 4th RBS to near or same room as the 3rd RBS or one of the other RBS and ethernet connect it directly behind this RBS to check to see if the system reports it being wired or wireless. Might be ethernet wiring is not working between the RBS in the wall or a bad jack.
Swap RBS around to see if the problem follows or not.
Check the cabling. CAT6 is recommended.
What FW version are you using?
- rafaleoOct 24, 2023AspirantHello,
