archaeus1
Oct 19, 2022Tutor
wired backhaul setup for orbi 753
Hello! I have a question for you: i want to replace my old network setup with a mesh system from netgear ( orbi rbk 753). Basically i want to change the current router with Orbi router and then via ...
Oct 19, 2022Guru - Experienced User
Yes you can use a switch in between the RBR and RBS.
NON Managed switch is recommended. NG GS-105/108v4 and GS308v3, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
archaeus1
Oct 19, 2022Tutor
I have the
TP-LINK TL-SG1016
- FURRYe38Oct 19, 2022Guru - Experienced User
Check it out and see if it works. Seen some non managed switches with Green Ethernet features cause problems with Orbi systems. Hopefully this will work though.
- archaeus1Oct 19, 2022Tutor
well i can't just check it out because i'm currentlly digging the forum to find out answers BEFORE i buy the Orbi 🙂
I have a big house with 2 storeys and want to form a new mesh network with the 2 sattelites wired far away from the router.
But thanks for the answer!
Best way would be to give it a try.
Yes, you can use managed switches. Maybe some configurations needed to make some of those work. IGMP Protocol is one that should be disabled from historical posts.
The mentioned brands and model switches are ones I've personally tested with my Orbi systems. They work.
If you get a Orbi system, let us know how it turns out for you. Need any assistance, please post here and we'll help ya out.
- plemansOct 19, 2022Guru - Experienced User
I'm running managed switches without issues. I'm not doing anything fancy with it and use it more as a learning experience.
But looking at that switch, it basically an unmanaged rackmount switch. Should be fine.
