archaeus1
Oct 19, 2022Tutor
wired backhaul setup for orbi 753
Hello! I have a question for you: i want to replace my old network setup with a mesh system from netgear ( orbi rbk 753). Basically i want to change the current router with Orbi router and then via ...
archaeus1
Oct 19, 2022Tutor
I have the
TP-LINK TL-SG1016
Oct 19, 2022Guru - Experienced User
Check it out and see if it works. Seen some non managed switches with Green Ethernet features cause problems with Orbi systems. Hopefully this will work though.
- archaeus1Oct 19, 2022Tutor
well i can't just check it out because i'm currentlly digging the forum to find out answers BEFORE i buy the Orbi 🙂
I have a big house with 2 storeys and want to form a new mesh network with the 2 sattelites wired far away from the router.
But thanks for the answer!
- FURRYe38Oct 19, 2022Guru - Experienced User
Best way would be to give it a try.
Yes, you can use managed switches. Maybe some configurations needed to make some of those work. IGMP Protocol is one that should be disabled from historical posts.
The mentioned brands and model switches are ones I've personally tested with my Orbi systems. They work.
If you get a Orbi system, let us know how it turns out for you. Need any assistance, please post here and we'll help ya out.
- archaeus1Oct 27, 2022Tutor
Bought the RBK753 and works like a charm. But when i set it up, the web interface keeps telling me that the 2 security questions are wrong but i'm 99.99% they are correct ... and now i have to reset and start from the begining....
