VerneArase
Mar 28, 2021Apprentice
Wired backhaul worth it for an AX6000 system?
*Sigh* ... I really have an RBK853 (AX6000) system, even though that's not an option in the forums even now. I'm thinking of wiring my house for ethernet and I've secured all the cable and equipm...
Apr 01, 2021Guru - Experienced User
Yes of course. Anything with device or traffic managment can impact speeds and performances. Also it can be MS services too. I was updateing BO5 the other night and was a 9Gb update, speeds started tanking near rock bottom speeds and was going to take over hours to complete I came back about 15 minutes later and the speeds were up over 200Mbps. It completed about 5-10 minutes later finally. So there is that. :smileyfrustrated:
DatabaseJase
Apr 05, 2021Luminary
Appreciate this is getting off topic but last night I noticed a message about downloads being slower due to a running game. I quit the game and downloads jumped to between 200Mbps-300Mbps so I expect the Xbox has worked that way for a while but now they are informing us of that limiting factor. Good to know Circle Home Plus is not causing the slow speeds.
- FURRYe38Apr 05, 2021Guru - Experienced User
Kewl, at least MS is getting a bit more informaative on there console.
