Yayo12
Dec 03, 2020Aspirant
Wired connection a fraction of Wifi
Model is the AX6000 RBK853 (I could not find it in the options above) https://www.netgear.com/orbi/rbk853.aspx Hey guys I just received my brand new Orbi mesh system and I am extremely excited ...
Yayo12
Thank you. Let me try to answer all the questions I currently have an answer to
The very last one. I installed this system on Tuesday and it immediatley asked me to update to the latest firmware. V3.2.16.22
Netgear CM1000
2252sq ft.
What is the distance between the router and satellite(s)?
The distance between the router and one of the satellites is not even 15 ft. This is because my internet cable comes directly to my TV room yet some of my computers are in an adjacent room. One of the reasons I purchased this system was to have ultra fast wired connection in this room. What i am finding though is that the wired speed coming from the satellites is not what I was expecting.
Where can I change the channels? I have clicked everywhere on the app and I cannot find that setting?
Yes there are neighbors, I can see a multitude of wifi networks on my mobile phone
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Try setting CTS to 2347. Save settings and reboot the router and satellite(s).
Where/how can I do all this?
If you mean "Armor" the security feature that comes with the app. I did disable that and my wired speed increased by about 30Mb but it was not considerable. Again, my issue is with the wired speed coming out of my satellites (both of them). If I connect directly to the router I do get my 1GB of speed.
Please help me by indicating where cna I go to change the channels and all the other settings you recommended.
Thank you
McLong
Dec 03, 2020Luminary
If I understand you correctly you are testing your wired connection using the same PC that you tested your new wireless AX card. Is your WiFi turned on and connected while also hard wired with ethernet cable? If so, just turn off your WiFi and try running a speed test again while hard wired to the RBR and RBS. Did this help?
