bpaskin
Oct 18, 2020Aspirant
Wired connections not working with Dynamic DNS
I have a weird connection issue that only happens with wired connections. Wireless connections are fine. I have a RBR850 router and RBS850 satellite, but I am only concerned about the router. Both...
bpaskin
Hi, thanks for the suggestion. It is working directly, so it must be the switch somehow. The interesting thing is that the switch (GS108E) works with the Nightwawk (R7800) fine. I restested and not an issue. So something about the Orbi doesn't like what is happening on the switch.
Brian
Oct 19, 2020Guru - Experienced User
The 108E is a smart managed switch. Manged switches are known to cause problems.
Try disabling IGMP protocols and any green ethernet features on this switch if they are accessible.
I can confirm the NGs GS 105/108v4 (non E version) switchs work with Orbi AX. Also D-Links DGS-105/108 and HP ProCurve 1400/1800 series work fine as well.
