phildeez
Dec 03, 2022Tutor
Wired devices not connecting
I have an Orbi 960 with two satellites. After firmware upgrade I had many issues. I've since done a hard reset with latest firmware and setting up from scratch. Currently I only have the Orbi route...
WiFiplease
Dec 09, 2022Aspirant
Hello, where you able to fix this issue. I'm having same. WiFi all work great but not the ports.
- phildeezDec 09, 2022TutorAfter several tests with support we determined that the physical ports were faulty and had to RMA a new device.
- WiFipleaseDec 09, 2022AspirantI had same issue but it was set to try and use the 2.5 as a backhaul after a manual update to the newest firmware and setting only as 10G they are all working now.
