phildeez
Dec 03, 2022Tutor
Wired devices not connecting
I have an Orbi 960 with two satellites. After firmware upgrade I had many issues. I've since done a hard reset with latest firmware and setting up from scratch. Currently I only have the Orbi route...
WiFiplease
Dec 09, 2022Aspirant
Hello, where you able to fix this issue. I'm having same. WiFi all work great but not the ports.
phildeez
Dec 09, 2022Tutor
After several tests with support we determined that the physical ports were faulty and had to RMA a new device.
- WiFipleaseDec 09, 2022AspirantI had same issue but it was set to try and use the 2.5 as a backhaul after a manual update to the newest firmware and setting only as 10G they are all working now.
