WRSORBI
Oct 23, 2022Luminary
Wired ethernet speed slow
I am having the same problem. It seems to have begun 2 weeks ago in my case when Windows11upgraded to 22H2. It is only affected wired ports. WiFi unaffected. It is affecting every PC upgraded to 22H...
- Oct 27, 2022
Had a network tech friend bring his Asus GT AX-11000 to test in my home and we experienced the ethernet throttling the same even with the Asus. He then turned off IPV6 on my NICs properties, rebooted, retested and problem is resolved. I now have full ~920Mbps download on a 1GbE NIC as expected from using either the Asus or the RBK852 simply using IPV4. Circumvention is to turn of IPV6 in NIC properties.
Oct 24, 2022Guru - Experienced User
CAT6 A STP is recommended between the RBR and CM modem.
Is this the only device that your seeing this with? Does this happen on other PCs or different windows versions?
What is the brand and model of the ethernet adapter with in the PC?
Ensure the ethernet adapter drivers are up to date.
Disable any ethernet adapter built in QoS features if it supports it.
Swap ethernet adapters to compare results
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Any of the following enabled?:
Armor, Circle, Traffic Meter
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
WRSORBI
Oct 24, 2022Luminary
My previous post did not make it for some reason. All of what you mention has been verified and done ad nauseum. Tests with Netgear support were extensive. NICS are Intel, Killer and Realtek. Results on each NIC the same when connected to RBR. Satellite not part of problem. Wifi speeds unaffected Problem is only with the (4) 1GbE LAN ports on RBR850. All NICS test full link speed when directly connected to Netgear CM2000 modem port. All cables confirmed in spec and are recent. No parental controls and Armor was tested with and without and made no difference, RBR Speedtest below and video showing NIC throttling with Speedtest is at https://www.youtube.com/shorts/5_82G_0I3jQ
- FURRYe38Oct 24, 2022Guru - Experienced User
So after the reset and setup from scratch the speed is good for a while then drops to a lower result?
Is the CAT6 cable between the Modem and RBR a CAT6A STP?
Are you testing different speed test servers on Ooklas speed test app to compare?
How many devices are connected entirely to the RBR?
Are you speed testing while other devices are online or just a wired PC?
FYI, Killer nics have there own QOS that can cause problems though if you tested with other nics, kinda doubt a nic problem. You should be seeing near 900Mpbs or just over all the time on the LAN ports.
- WRSORBIOct 24, 2022Luminary
These cables have all been verified with Netgear support. Netgear CM2000 modem ships with 10GbE CAT6A STP yellow cable. Testing is done ONLY with NIC attached. No other devices active. Very aware of Killer Performance Suite and this is deinstalled on all PC's with Killer NIC's. Have tried different server providers through Ookla, Fast,com, M-lab, Xfinity speed tests. All same results.
After reset, after new modem, results are the same. NIC ports are throttled.
