TheControlVoice
Sep 07, 2022Follower
Wired LAN dropping on Orbi Mesh WiFi 6E System - AXE11000 with ATT BGW210-700
I have been unimpressed with the Mesh offered by ATT and the WiFi seemed to be spotty. So I bought the Orbi Mesh WiFi 6E System - AXE11000 to replace everything except the modem since I am required t...
Sep 07, 2022Guru - Experienced User
Try leaving the bgw in router mode (disable its wifi) and connect the orbi in router mode.
it wouldn't be the first time I've seen the bgw not work properly in passthrough mode.
TC_in_Montana
Sep 08, 2022Virtuoso
Do you have the "Separate 6GHz Network" option enabled? We have seen this cause some issues with the ATT BGW210 series as well.
Please note that if you want/need 6GHz (WiFi 6E) connectivity - there is a 6GHz band broadcasting using your standard (main) SSID. Enabling the "Separate 6GHz Network" adds an additional 6GHz SSID under a different name, but using same channel as the one using the main SSID.
Our recommendation is to disable that option and connect to the 6GHz on the main SSID.
Unfortunately, the User Manual doesn't describe the 6GHz functionality very well so many users believe they have to enable that one option to get WiFi 6E (6GHz) capabilities.
