WilliamGr
Feb 07, 2024Guide
Wired satellite not showing up on Attached Devices
I'm having this exact issue, and it's driving me insane. Just picked up a RBK963. Everything working great, but I need to put the router into AP mode. So I did that, and all was well (as long as I use the WAN port or I get a bright magenta light). Problem is that both of my satellites (wired) disappear from the Orbi app, so I have no idea what's connected to which of them via WiFi.
I honestly thought I'd be done with this mess when I upgraded from the RBK53, but... nope.
Is there any way around this? Seems like such a simple setup that it boggles my mind it's so tricky to get working.
My Fiber ONT -> Edgerouter ER-4 -> Orbis in AP mode.
How are the Orbi units connected?
For example, if the Orbi router WAN port is connected to the Edgerouter, and the Orbi satellites are connected to the Orbi router over WiFi or using the Orbi router LAN ports, then it should work correctly.
On the other hand, if all of the Orbi units are connected directly to the Edgerouter, the satellites will 'disappear'.
Is there perhaps another switch in the network?
- Thanks so much for the reply!
My main Orbi is connected via the WAN port (LAN port just gives me permanent magenta and no internet) to an unmanaged 5-port switch which connects to the gigabit jack in the wall. That then goes upstairs to another unmanaged switch in my panel (bedroom closet), and that switch connects into my Edgerouter 4 (which has my fiber config). So basically it’s the fiber ONT which connects to the panel, which then connects to the Edgerouter ER-4 which connects to the 16 port unmanaged switch, and then all the rooms are connected from that switch.
The other Orbis are connected the same way. In rooms connected to a small unmanaged switch (5 ports I believe) and then back to that panel in my closet.
Hopefully that makes sense.
PS There are double runs of Ethernet to each room from the panel. I’ve only wired up one end in each room but I can do two. Just an fyi…- CrimpOnGuru - Experienced User
You are SO LUCKY. (two Ethernet cables from the patch panel to each room.)
The correct connection sequence is:
Fiber ONT to Edgerouter. (if they are co-located, then no patch panel)
Edgerouter to Orbi WAN port using one Ethernet cable.
Orbi LAN port using the other Ethernet cable back to 16 port switch.
Connect everything else to the 16 port switch.
The key is that the link between Edgerouter and Orbi WAN port must not go through the switch.
