Chicago_Joe
Apr 30, 2023Aspirant
Wired Satellites and IP Address Issues
I have a RBK852 system - one satellite. I have the satellite connected in wired mode (in wireless, signal was poor). I have the satellite assigned a static IP address of 192.168.66.3 (router is 192...
Apr 30, 2023Guru - Experienced User
What FW version do you have loaded on the RBS and RBR?
How is the RBS ethernet connected to the back of the RBR? Directly to the back or is there a ethernet LAN switch in between? Brand and model of switch please.
What CAT# lan cable are you using between the RBS and RBR? CAT6 is recommended.
What browser are you using?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
