Magician1979
Dec 22, 2020Aspirant
Wireless signal on a hard wired Orbi satellite
Do the Orbi satellites still produce a wireless signal if you hardwire them to your Orbi router? Currently using the RBK853 with two satellites. If it does produce a wireless signal while hard wired ...
Dec 22, 2020Guru - Experienced User
Yes the 5Ghz AX backhaul is still being broadcast. It can't be disabled.
So the connection rate on the wireless backhaul of the AX series is 2400Mpbs while the wired back haul is 1000Mbps. So you can see there is a difference. This is just a connection rate between the RBS and RBR only.
Magician1979 wrote:Do the Orbi satellites still produce a wireless signal if you hardwire them to your Orbi router? Currently using the RBK853 with two satellites. If it does produce a wireless signal while hard wired to the router, will it produce a stronger wireless signal and increase speeds? Hope that makes sense
- Magician1979Dec 22, 2020Aspirant
If that's the case, Does that increase the speed I should be getting? Getting somewhere around 400mbps WiFi signal on other side of house so wondering if hardwiring it will increase its WiFi speed.
- CrimpOnDec 22, 2020Guru - Experienced User
Magician1979 wrote:If that's the case, Does that increase the speed I should be getting? Getting somewhere around 400mbps WiFi signal on other side of house so wondering if hardwiring it will increase its WiFi speed.
Ethernet backhaul will almost always produce greater througput than WiFi backhaul, even the "wonderful" WiFi6 backhaul.
The main issue is that ethernet is a full duplex connection, where data can flow simultaneously in both directions at almost full speed.
WiFi is a "one radio broadcasts at a time" system, while the others back off and wait until the channel is free. So, if one satellite broadcasts packets to anywhere (the router or another satellite), those other two go silent until it is finished. There are also regular "management" frames sent to maintain the WiFi link, which eat into capacity. My guess is that for most systems, a huge percentage of data is flowing from the router to satellites (internet streaming, for example).
There are tools that can be used to measure network throughput. iPerf3, for example, will send packets from one computer to another as fast as can be done. I regularly measure over 950mb/sec between computers connected directly to the Orbi router over gigabit ethernet links. If multiple tests were going on at the same time over the WiFi backhaul, that might give an idea of how much capacity the backhaul link has.
The User Facing WiFi signal is also a function of the actual device and how close it is to the Orbi unit. 2.4 WiFi "tops out" at a link rate of 400mb.
- FURRYe38Dec 22, 2020Guru - Experienced User
Wired or wireless will not increase the speed. Other factors contribute to getting good or bad perfomances. Distance, building materials, noises and signal qualtity will effect performance.
These are the connection rates that Orbi AX 8 series supports:
2400(wireles backhaul) + 2400(5Ghz wireless front haul with connected devices) + 1200Mbps(2.4Ghz wireless front haul with connected devices)
Front haul also depends on connected wireless device support. Not all devices support these rates.
Wireless can be simultanious if MIMO is supported on the wireless device. "MU-MIMO capable for simultaneous data streaming."
I would presume that if the Orbi AX is setup well and RBS are connected fully at 2400Mpbs backhaul and your environment is good, and you have good devices that are fully supporiting of AX modes and rates, you should see same or near same performances as on the wired 1000Mpbs connected line.
- Magician1979Dec 23, 2020Aspirant
It still broadcasts both the 2.4 and 5G signals while wired, correct?
- CrimpOnDec 23, 2020Guru - Experienced User
Magician1979 wrote:It still broadcasts both the 2.4 and 5G signals while wired, correct?
Yes, both the 2.4G and 5G "user facing" channels continue to be active. And, the 5G "backhaul" channel continues to be active, although sending only "management frames" rather than data.
